Folgendes Backup Script dient als Beispiel wie eine einfache Datensicherung eingerichtet werden kann. Es ersetzt keine professionelle Lösung!
Auf eigene Gefahr
Dieses Script löscht Dateien! Bitte auf eigene Gefahr anwenden! i-doit GmbH übernimmt weder Garantie noch Support und schließt eine Haftung für Folgeschäden aus.
#!/bin/bash
#### System requirements
#### The following tools need to be installed:
### mysql - for the MySQL database backup
### tar - for the file backup
### ncftp - for the FTP file copy
### samba-common - For the CIFS file copy
### cifs-utils - For the CIFS file copy
### Debian install example:
### apt-get install samba-common cifs-utils ncftp mysql-client tar
## Global configuration options
glob_machine="idoitserver" #Machine name to label backup files
glob_date=$(date +"%Y-%m-%d_%H%M") #Date format to label backup files (default is 2015-12-12_1755)
glob_path="/tmp/backup/${glob_machine}" #Specify local backup path
glob_delete=0 #Delete local files immediately after CIFS or FTP copy?
## Database backup configuration
backup_database=1 #Database backup enabled?
db_user="" #MySQL username
db_pass="" #MySQL password
db_host="127.0.0.1" #MySQL host
db_names="idoit_system idoit_data" #Database names to backup separated with space
## File backup configuration
backup_file=1 #File backup enabled?
file_files="/var/www" #File paths to backup separated with space
## FTP configuration
copy_ftp=0 #Copy files to FTP server?
ftp_user="" #FTP username
ftp_pass="" #FTP password
ftp_host="" #FTP servername or IP address
ftp_path="/backup/path" #Backup path on FTP server
## CIFS configuration
copy_cifs=0 #Copy files to CIFS Share?
cifs_user="" #CIFS username
cifs_pass="" #CIFS pass
cifs_path="//cifs/file/share/path" #CIFS backup path
cifs_mount="/tmp/backup/cifs_mnt" #CIFS share mount point
cifs_domain="" #CIFS domain name
## Old files deletion
delete_file=0 #Delete old local backups?
delete_file_age=7 #Delete local backups older than x days
delete_cifs=0 #Delete old cifs backups?
delete_cifs_age=7 #Delete cifs backups older than x days
#-------------------------- Stop editing here --------------------------
mkdir -p ${glob_path}
umask 177
#Mount CIFS share
if [ $copy_cifs -eq 1 ];
then
echo "Mounting CIFS share ${cifs_path} to ${cifs_mount}"
mkdir -p ${cifs_mount}
/sbin/mount.cifs ${cifs_path} ${cifs_mount} -o user=${cifs_user},domain=${cifs_domain},password=${cifs_pass}
fi
#Database backup
if [ $backup_database -eq 1 ];
then
for i in ${db_names}
do
if [ -n "$i" ];
then
tmp_sqlfile=${glob_path}/${glob_machine}__${i}__${glob_date}.sql
echo "Dumping MYSQL database ${i} to file ${tmp_sqlfile}"
/usr/bin/mysqldump --user=${db_user} --password=${db_pass} --host=${db_host} ${i} > ${tmp_sqlfile}
if [ $copy_ftp -eq 1 ];
then
echo "Copying ${tmp_sqlfile} to FTP server ${ftp_host}"
/usr/bin/ncftpput -u ${ftp_user} -p ${ftp_pass} ${ftp_host} ${ftp_path} ${tmp_sqlfile}
fi
then
echo "Copying ${tmp_sqlfile} to CIFS share ${cifs_path}"
cp -f ${tmp_sqlfile} ${cifs_mount}
fi
if [ $glob_delete -eq 1 ];
then
echo "Immediately deleting file ${tmp_sqlfile}"
rm -f ${tmp_sqlfile}
fi
fi
done
fi
#File backup
if [ $backup_file -eq 1 ];
then
j=1
for i in ${file_files}
do
if [ -n "$i" ];
then
tmp_filesfile=${glob_path}/${glob_machine}__${j}__${glob_date}.tar.gz
echo "Packing files ${i} to ${tmp_filesfile}"
tar czf ${tmp_filesfile} $i
j=$((j + 1))
then
echo "Copying ${tmp_filesfile} to FTP server ${ftp_host}"
/usr/bin/ncftpput -u ${ftp_user} -p ${ftp_pass} ${ftp_host} ${ftp_path} ${tmp_filesfile}
fi
then
echo "Copying ${tmp_filesfile} to CIFS share ${cifs_path}"
cp -f ${tmp_filesfile} ${cifs_mount}
fi
then
echo "Immediately deleting file ${tmp_filesfile}"
rm -f ${tmp_filesfile}
fi
fi
done
fi
#old backup deletion
if [ $delete_file -eq 1 ];
then
echo "Deleting files older than ${delete_file_age} days in ${glob_path}"
find ${glob_path} -maxdepth 1 -mtime +${delete_file_age} -exec rm {} \;
fi
then
if [ $delete_cifs -eq 1 ];
then
echo "Deleting files older than ${delete_cifs_age} days on CIFS share ${cifs_mount}"
find ${cifs_mount} -maxdepth 1 -mtime +${delete_cifs_age} -exec rm {} \;
fi
fi
#Not implemented so far
#if [ $copy_ftp -eq 1 ];
#then
#fi
#Umount CIFS share
then
echo "umounting CIFS share ${cifs_mount}"
umount ${cifs_mount}
fi
