i-doit QR-Code Printer#
You can find a practical example on our Blog
In i-doit, you automatically generate barcodes or QR codes for all objects. You can use these, for example, to print machine-readable labels. After configuration, the code appears in the upper right corner as soon as you select an object.
Barcode#
A barcode is an optoelectronically readable font made of bars and gaps of varying widths. The disadvantage: A barcode can only store relatively little information.
QR code#
The QR code (Quick Response) is a two-dimensional code with automatic error correction. Its advantage over the barcode: It stores significantly more information.
QR code or barcode configuration#
The configuration within i-doit can be found under Administration → Predefined content → QR code
Here you activate or deactivate the code display and choose between barcode and QR code.
QR code content configuration#
You configure which information is stored in the QR code under Administration → Predefined content → QR code:
Global definition#
With the global definition, you fill the QR code information using the following placeholders:
Modifiers since i-doit 39
Since i-doit 39, the placeholders can be transformed with modifiers, for example %hostname|lower%. The complete list is available under QR code.
Primary access URL#
With this option, only the URL stored in the object is included in the QR code.
QR code linking#
Specify what happens when clicking on the code: Either the QR Code Printer tool opens or a popup with the standard print function of your operating system.
Text template#
Here you combine free text with placeholders from i-doit and format the label to your requirements.
Logo for print view#
Upload an image file -- it is automatically integrated into every label.
With the QR Code Printer, you conveniently print labels on your label printer. You configure the formats to match your specifications. When someone scans the QR code with a smartphone or tablet, they are redirected directly to the overview page of the object.
Installation and download#
- Download the QR-Code Printer add-on from the customer portal.
- Install it via the Admin Center.
- In i-doit, open Add-ons → QR-Code Printer. The page shows a short description of the add-on.
- Click download to get the Windows application as a ZIP file (for add-on version 1.5.1:
qr-code-label-printer_1.5.zip). - Extract the ZIP file and start
qr-code-label-printer_1.5.exe. The Windows application starts directly, no installation is required.
Start and configuration#
To set up the connection:
- Open File → Options → i-doit API Settings.
- Enter the URL of your i-doit installation, the API key, and the credentials of a user with API permission.
The i-doit API key
You can find the API key of your installation in i-doit under Administration → Add-ons → JSON-RPC API
Print parameter configuration#
Under File → Options, you configure all print parameters:
- Margins and label size -- Adjust the dimensions to your label format.
- QR-Code Positioning -- Define position (in pixels), size, font, and font size.
- Logo -- Select a logo in a common image format under Path and position it via the parameters.
Tip
Define the Dymo Label Writer as the default printer and set the paper format to horizontal.
Printing labels#
To print a label:
- Enter the object ID of the desired object.
- The barcode information is automatically loaded from i-doit -- you can edit it if needed.
- Print, save, or export the QR code via the icons or File in the context menu. Export is in
.bmpformat.
Releases#
| 1.5.1 | 03.11.2026 | [Task] Compatibility towards i-doit 40+ |
| 1.5 | 24.01.2023 | [Bug] Fix the configuration of the Text margin |
